  2. Logic Design
  3. error in waveform generation
  • Subscribers 63
  • Views 15421
lov sareen
lov sareen over 15 years ago
 hi,
i am doing a project on synchronous fifo design using verilog. below written is my coding. after simulation the waveform is showing error regarding its not giving value of rdata_valid and is showing a red line in waveform and due to it address is also not being taken.i have attached the waveform also. the logic for write logic is also not accepting the address(no change occurs while changing value of read_ptr).
plz help me out in this. your guidance and solns will help me in completing my project work.
thank you
lov sareen
////TOP LEVEL MODULE////
modulesync_fifo#( parameter addr_width=4,
parameterdata_width=16,
parameter depth=16,
parameteraempty=3,
parameterafull=3)
//INPUTS//
inputclk,                               //clock input
inputreset_n,                          //reset
input flush,                            //flush
input [data_width-1:0] write_data,     //write data
inputwdata_valid,                    //write valid data
inputread_req,                        //read request
//OUTPUTS//
output [data_width-1:0] read_data,   //read data
outputrdata_valid,                  //read data valid
outputfifo_empty,                   //fifo empty flag
outputfifo_aempty,                  //fifoalmostempty flag
outputfifo_full,                    //fifo full flag
outputfifo_afull,                   //fifoalmostempty flag
outputwrite_ack                   //write acknowlegment
//Internal wires//
wire [addr_width:0] read_ptr;        //read pointer
wire [addr_width:0] write_ptr;      //write pointer
wirerd_en;                          //read enable
wirewr_en;                          //write enable
write_control_logicwrite_cntl(
.read_ptr(read_ptr),
.flush(flush),
.reset_n(reset_n),
.clk(clk),
.wdata_valid(wdata_valid),
.write_ack(write_ack),
.wr_en(wr_en),
.write_ptr(write_ptr),
.fifo_full(fifo_full),
.fifo_afull(fifo_afull)
read_control_logicread_cntl(
.clk(clk),
.reset_n(reset_n),
.flush(flush),
.read_req(read_req),
.rd_en(rd_en),
.rdata_valid(rdata_valid),
.fifo_empty(fifo_empty),
.fifo_aempty(fifo_aempty)
memory_arraymem_arr(
.write_addr(write_ptr[addr_width-1:0]),
.read_addr(read_ptr[addr_width-1:0]),
.wr_en(wr_en),
.rd_en(rd_en),
.clk(clk),
.write_data(write_data),
.read_data(read_data)
endmodule
//write control logic//
module write #(
parameteraddr_width=4,
parameterafull=3,
parameter depth=16)
// Inputs//
inputclk,
inputreset_n,
input flush,
inputwdata_valid,
input [addr_width:0] read_ptr,
// Outputs//
outputregwrite_ack,
outputwr_en,
outputreg [addr_width:0] write_ptr,
outputfifo_full,
outputregfifo_afull
//Internal wires//
wire [addr_width-1:0] write_addr;
wire [addr_width-1:0] read_addr;
//Read and Write addresses from their pointers//
assignread_addr= read_ptr[addr_width-1:0];
assignwrite_addr= write_ptr[addr_width-1:0];
//When fifo is full there will be no write//
assignwr_en= wdata_valid&&(~fifo_full);
//Logic for fifo full status//
//Fifo full is asserted when both pointers are at same address but msb are different//
assign fifo_full=((write_addr==read_addr)&&(write_ptr[addr_width]^read_ptr[addr_width]));
//Logic for almost full status//
always @*
begin
if(write_ptr[addr_width]==read_ptr[addr_width])
fifo_afull=((write_addr-read_addr)>=(depth- afull));
else
fifo_afull=((read_addr-write_addr)<=afull);
end
//Logic for Write pointer//
always @(posedgeclk or negedgereset_n)
begin
if (~reset_n)
begin
write_ptr<={(addr_width+1){1'b0}};
write_ack<=1'b0;
end
else if(flush)
begin
write_ack<=1'b0;
end
else if(wr_en)
begin
write_ptr<=write_ptr+{{addr_width{1'b0}},1'b1};
write_ack<=1'b1;
end
else
begin
write_ack<=1'b0;
end
end
endmodule
//Read control logic//
module read #(
parameteraempty=3,
parameter depth=16)
//Inputs//
inputclk,
inputreset_n,
input flush,
inputread_req,
input [addr_width:0] write_ptr,
//Outputs//
outputrd_en,
outputregrdata_valid,
outputfifo_empty,
outputregfifo_aempty,
outputreg [addr_width:0] read_ptr
//Internal wires//
//Read and Write address from their pointers//
assignread_addr=read_ptr[addr_width-1:0];
assignwrite_addr=write_ptr[addr_width-1:0];
//FIFO is empty when read pointer is equal to write pointer//
assignfifo_empty=(read_ptr==write_ptr);
//When FIFO is empty there will be no read//
assignrd_en=read_req&&(~fifo_empty);
// Logic for almost empty flag//
always @*
begin
if (read_ptr[addr_width]==write_ptr[addr_width])
fifo_aempty=((write_addr-read_addr)<= aempty);
else
fifo_aempty=((read_addr-write_addr)>=(depth - aempty));
end
//Logic for Read pointer and read valid data//
begin
if (~reset_n)
read_ptr<={(addr_width+1){1'b0}};
else if (flush)
else if (rd_en)
begin
read_ptr<=read_ptr+{{addr_width {1'b0}},1'b1};
rdata_valid<= 1'b1;
end
else
rdata_valid<= 1'b0;
end
endmodule
//Memory array//
module memory #(
parameter depth=16,
parameterdata_width=16)
//Inputs//
input [addr_width-1:0] write_addr,
input [addr_width-1:0] read_addr,
inputwr_en,
inputrd_en,
inputclk,
//Output//
outputreg [data_width-1:0] read_data
//Register//
reg [data_width-1:0] memory [0:depth-1];
//Write into memory(data-in)//
always@(posedgeclk)
begin
if(wr_en)
memory[write_addr]<= write_data;
end
//Read from memory(data out)//
always@(posedgeclk)
begin
if(rd_en)
begin
read_data<= memory[read_addr];
end
end
endmodule
parameter depth=16,
parameteraempty=3,
parameterafull=3)
//INPUTS//
//OUTPUTS//
//Internal wires//
.flush(flush),
.reset_n(reset_n),
.clk(clk),
.wr_en(wr_en),
.clk(clk),
.reset_n(reset_n),
.flush(flush),
.rd_en(rd_en),
.wr_en(wr_en),
.rd_en(rd_en),
.clk(clk),
endmodule
module write #(
parameterafull=3,
parameter depth=16)
// Inputs//
inputclk,
inputreset_n,
input flush,
inputwdata_valid,
// Outputs//
outputregwrite_ack,
outputwr_en,
outputfifo_full,
outputregfifo_afull
//Internal wires//
always @*
begin
else
end
begin
if (~reset_n)
begin
write_ack<=1'b0;
end
else if(flush)
begin
write_ack<=1'b0;
end
else if(wr_en)
begin
write_ack<=1'b1;
end
else
begin
write_ack<=1'b0;
end
end
endmodule
module read #(
parameteraempty=3,
parameter depth=16)
//Inputs//
inputclk,
inputreset_n,
input flush,
inputread_req,
//Outputs//
outputrd_en,
outputfifo_empty,
//Internal wires//
always @*
begin
else
end
begin
if (~reset_n)
else if (flush)
else if (rd_en)
begin
rdata_valid<= 1'b1;
end
else
rdata_valid<= 1'b0;
end
endmodule
//Memory array//
module memory #(
parameter depth=16,
//Inputs//
inputwr_en,
inputrd_en,
inputclk,
//Output//
//Register//
always@(posedgeclk)
begin
if(wr_en)
end
always@(posedgeclk)
begin
if(rd_en)
begin
end
end
endmodule
  • croy
    croy over 15 years ago
    Hi Lov
    You might get more replies if you post this type of (non-tool related) questions to a forum like groups.lang.verilog.
    Chrystian
