  2. Logic Design
  3. RC ; sdc ; load_of
  • Subscribers 64
  • Views 19271
RC ; sdc ; load_of
Yemelya
Yemelya over 15 years ago
There is a problem to use the following syntax of SDC constraints for RC by read_sdc, since RC doesn’t recognize “load_of”.
set_load [expr 30 * [load_of [get_lib_pins lib_name/inv3/A]]] [all_outputs]
How can I translate this to make it compatible with RC?
Thanks a lot!
Boris
  • grasshopper
    grasshopper over 15 years ago
     Hi Boris,
     problem is load_of is not an SDC command. There are a number of things you can do
    (1) create a load_of procedure in TCL along the lines of
    proc load_of {args} {
       set libCellPath [find / -null_ok -libpin $args]
       if {$libCellPath != {}} {
          set load [get_liberty_attribute capacitance $libCellPath]
       } else {
          set load 0
       return $load
    (2) User RC syntax
      set_attribute external_pin_cap [expr 5 * [lindex [get_attr capacitance $load_pin] 0]] [all des outs]
    note that the expression  'lindex [get_attr capacitance $load_pin] 0' is needed since it provide values for rising and falling edges. Also $load_pin is the ouput of something like 'find /libraries -libpin . ...]
    hope this helps,
    gh-
    archive over 15 years ago
    Below statement is the equivalent of what you are looking for.
    set_load [expr 30 * [lindex [get_attribute capacitance [get_lib_pins lib_name/inv3/A]] 0] ] [all_outputs]
     P.S.: lindex 0 is being taken considering rise cap value
  • Yemelya
    Great! Thanks a lot!!!
  • Wini
    Wini over 13 years ago
    There's a problem: [get_attribute capacitance ...] only gives the capacitance in fF
    rc:/> get_attribute -h capacitance libpin
      get_attribute: returns an attribute value from an object
    Usage: get_attribute <string> [<object>+]
        <string>:
            attribute name
        [<object>+]:
            object of interest (must be unique)
        attribute category: lib_ui
        attribute name: capacitance
              category: lib_ui (returns Liberty attribute cell information)
           object type: libpin
           access type: read-write
             data type: capacitance rise/fall
         default value: 0.0 0.0
                 units: femtofarads
                  help: The rise/fall capacitance.
    So you have to divide the retrieved value by 1000 as RTL compiler computes in pF.
  • grasshopper
    grasshopper over 13 years ago
     That would be correct. The good news is RC is consistent and always return in fF independent of library units so once you fix the proc, you should be good to go
    good luck,
    gh-
