  2. Logic Design
  3. Black Boxes
  • Subscribers 63
  • Views 15394
Black Boxes
AMit Raj
AMit Raj over 15 years ago
While running LEC i got may unreachable blackboxes, can anyone tell me how to remove these BlackBoxes..??
  • croy
    croy over 15 years ago
    What do you mean by "remove"? Remove from the reporting or remove from the design?
    Unreachables are a problem only if unexpected. You can do "report gate -unreach" to see why a point is unreachable (no path to an output through any sort of logic, therefore it has no effect, therefore LEC doesn't map nor compare it).
    Typical unreachables:
    1) unused logic in RTL
    2) spare gates
    3) disable test logic
    4) clock-gating latches (after modeling with set flatten model gated_clock)
