  2. Logic Design
  3. abort points in conformal
  • Subscribers 63
  • Views 16498
battunvn
battunvn over 15 years ago
hi , iam naveen
 i am testing LEC for a big module using conformal..
 i got abort points ..and using analyze abort -compare command i tried to solve the issue..
 but the number is not decreasing to zero.
 Can anyone help me how to apply test vectors in schematic and check the LEC for abort points manually
  • croy
    croy over 15 years ago
    Hi Naveen
    Have you had a look at this paper available at support.cadence.com?
    "Guidelines for handling aborts with Encounter Conformal equivalency checking"
    Chrystian
