  2. Logic Design
  3. Welcome
  • Subscribers 62
  • Views 15091
Welcome
archive over 21 years ago
Welcome to the digital IC Synthesis and Test forum; a place to keep your finger on the pulse of the latest software developments and happenings in the areas you care about most. Get to know the experts, both inside Cadence and in our worldwide Encounter user community. Ask your questions, get answers, and share best practices. Tell us what's on your mind...other users want to know what you think.
This forum is not intended to be a substitute for Cadence customer support and/or documentation, but we do believe that it will be helpful and a way to tap into vast knowledge that exists in our user community. Of course, any software support, documentation and installation issues should also be directed to your preferred Cadence support channels.
File attachments must use one of the following file extensions: .exe, .doc, .pdf, .html or .zip. Size limit on the attachments is 500KB. If you have questions or need help with attachments, send an email to community_moderator@cadence.com
Originally posted in cdnusers.org by Moderator
    I have a question on read_hdl on Encounter RTL compiler. It seems that it doesnt accept following code snippet
    read_hdl -verilog {$rtl_list}
    I created a run file to read in all the files for synthesis into the rtl_list.
    Still the rtl compiler complains VLOGPt-650.
    vinil
    Originally posted in cdnusers.org by vinilt
