  2. Logic Design
  3. read_hdl fails to open rtl_list
  • Subscribers 61
  • Views 17836
archive over 21 years ago
I have a question on read_hdl on Encounter RTL compiler. It seems that it doesnt accept following code snippet
read_hdl -verilog {$rtl_list}
I created a run file to read in all the files for synthesis into the rtl_list. I can list all the elements in the rtl_list like
a.v
b.v
... z.v
Still the rtl compiler complains VLOGPT-650.
vinil
Originally posted in cdnusers.org by vinilt
    Vinil,
    Here is a reply from Cadence engineering:
    Hi Vinil,
    There are two syntax issues with the read_hdl command you've posted:
    1. -verilog is not an option to read_hdl. By default, read_hdl reads Verilog files, so no switch is necessary to specify Verilog input. Please do read_hdl -h to see the valid options
    2. In TCL, surrounding a variable with {} means to not expand that variable its values. As a result, the read_hdl command is looking for a file called $rtl_list, not looking for the files specified in $rtl_list.
    I think you will find that the following command will accomplish what you need:
    read_hdl $rtl_list
    Thank you for your post.
    moderator
    Originally posted in cdnusers.org by Moderator
