  2. Logic Design
  3. Redirecting a command output to a file.
  • Subscribers 62
  • Views 27121
nozuey
nozuey over 15 years ago
How can I redirect the output from    puts [find / -instance "U_*"]   to a file  on RTL Compiler ?
 I simply tried > and this is what I got.
rc:/designs> puts [find / -instance "U_*"]  > inst
bad argument "inst": should be "nonewline"
I also wonder why redirection with > works differently on different commands, even though they all output the results to STDOUT.  I mean "report area > file" works, but find / -instance "*" > file does not.  Any thoughts ?
  • grasshopper
    grasshopper over 15 years ago
     Hi nozuey,
     remember that the RC shell / session is a TCL shell and not the same as *nix shell hence command syntax is not the same. Some commands do support the '>' redirection characters as an option but not all do. Using the -help option of any command should make that evident. The reirect command is usually your best bet for redirection so you can do something like
    redirect <file name> { puts [find ....] }
    or simply put things into a variable for processing using something like
     set my_var [find...]
    hope this helps,
    gh-
  • bmiller
    bmiller over 15 years ago
    In addition to what grasshopper mentioned, you can consider using standard TCL syntax to output "puts" to a file:
    set _file [open file.txt w]
    puts $_file [find ....]
    close $_file
    Or, to output the result one line at a time:
    foreach i [find ....] {puts $_file $i}
    close $_file
    Good Luck!
