  2. Logic Design
  3. LEC - Not-mapped key points
  • Replies 7
  • Subscribers 62
  • Views 9252
AMit Raj
AMit Raj over 15 years ago
I have a big design and after running LEC i got some Nop mapped key points. Can you please tell me, how can we map the Not-Mapped key points..
Amit Raj
  • croy
    croy over 15 years ago
     Hi Amit
    Can you give more details? How many? For the golden? For the revised?
    Mapping is discussed in the jumpstart training available at trainingondemand.cadence.com. You can use your Cadence Online Support username/password for access. There's a training on diagnosis that's very interesting.
    Chrystian
  • AMit Raj
     14 for golden and 12 for revised
  • croy
    For that small a list I would do 'add mapped points'.
    Chrystian
  • AMit Raj
    I also did the same but the number of NotMapped points in golden and revised are unequal.. 14 and 12.. and it has so many unreachable points.. suggest me some solutions...
    Thanks and Regards,
    AMit Raj
  • croy
    Hi Amit
    Having a few more not-mapped in the golden than in the revised is not unusual. They'll usually be found 'extra' post-compare.
    Please create a Service Request at http://support.cadence.com so someone from Customer Support can look at your log and at 'report unmapped points -not'.
    Chrystian
  • AMit Raj
    Actually because of UnMapped points I am getting many Non Equivalent points in flatten model but getting equivalent in Hierarchical for the same points..
    Can you please tell me the reason and can you suggest me something to overcome this...
    Thanks in advance,
    Amit Raj
  • croy
     Hi Amit
    Please create a Service Request at http://support.cadence.com so someone from Customer Support can look at your log and at 'report unmapped points -not' but if hierarchical passes then you're done.
    Chrystian
