  2. Logic Design
  3. LEC- CUT POINTS
  • Subscribers 62
  • Views 4840
LEC- CUT POINTS
battunvn
battunvn over 15 years ago
hi ,
i have a design with combinational loops .
 i see during LEC the tool introduced a extra cut point even though there is no loop. golden has 2 cut points while revised has 3 cut points.
that extra cut point in revised is wrongly mapped with cut point in golden.
can anyone tell me how to delete the extra cutpoint and correctly map the cut points
thank you in advance ,
naveen
  • croy
    croy over 15 years ago
    Hi Naveen
    Please move to our latest release if you're still using 8.1. 10.10-s540 is available at http://downloads.cadence.com.
    If that doesn't solve the problem check out Solution 11191670 at http://support.cadence.com.
    Chrystian
