  2. Logic Design
  3. RC report gates
  • Subscribers 62
  • Views 15478
RC report gates
Stevan
Stevan over 14 years ago
Hi all,
 If I use the report gates command in order to get a report of number of cells that were implemented, then I also get the area report for implemented cells. I've checked the values from .lib file with the given numbers for area of a certain cell, and the values match (depending on the number of that cell implemented). So the question is: In what units are the area values expressed in the .lib file?
Thanks!
 R
Stevan
  • grasshopper
    grasshopper over 14 years ago
    Hi Stevan, the .lib does not necessarily define the area. The library vendor documentation frequently specifies this but varies vendor to vendor. Some libraries are specified in um while others use area 1 for a standard NAND independent from the real physical size. hope this helps, gh-
