  2. Logic Design
  3. Anyone ever import an ATE tester STDF fail log into Encounter...
  • Subscribers 63
  • Views 14563
Anyone ever import an ATE tester STDF fail log into Encounter Diagnostics?
SteveJ
SteveJ over 14 years ago
STDF, an industry standard format and yet Encounter only supports Chip Pad Pattern (CPP) and it's own format generated output. The convert_failures_to_cpp.pl script seems too generic to be of much use and the instructions leave much to be desired as it doesn't line-up with standard output from a tester.
Some of the documents on Cadence solutions seem to imply that Encounter Diagnostics in Volume mode will take in an SQL style database but once again user guide rather vague, more like you have to build that from CPP inputs for different die.
