  2. Logic Design
  3. RTL compiler - synthesis
  • Subscribers 62
  • Views 2983
Ivan13
Ivan13 over 14 years ago
 I am traying to synthesize a design to a library with no basic inverters. In general, RTL compiler requires inverters and some other basic cells. and so i will recieve : "synthesis failed- do not have usable inverters".
My library have all the logical veriaty of cells except a straight forward inverter. meaning, including: (A+B'), AB', A(BC)'...... and alot more options to create an inverter out of them.. or to combine it with the approximate cells for one of the above functions .
There-for, from the aspect of logical veriaty the synthesizer can deal with no specific inverters. Can I some-how delete this requirement of implicitly have an inverter cell ?   or am i some-how hitting on some heuristics that suddenly are invalid with the absence of the inverter??
 Thank you very much
  • grasshopper
    grasshopper over 14 years ago
    Hi Ivan13, depending on what you are trying to do, it may be possible depending on your exact requirements. Please contact your local support and describe your specific requirements and they should be able to help regards, gh-
