  2. Logic Design
  3. ideal network in RC
  • Subscribers 61
  • Views 16609
ideal network in RC
archive over 19 years ago
I would like to know what is the preferred way to set clock nets as ideal in RTL Compiler.
Should I set the ideal_network attribute or use the "set_ideal_network" command in SDC?
Originally posted in cdnusers.org by myazdani
    It really doesn't matter as far at the tool is concerned. The advantage of doing int in SDC is that it becomes
    more portable, for example if you use the SDC in Encounter Timing System.
    Note, however, that clocks are ideal by default in RC.
    Originally posted in cdnusers.org by galaxy_jason
