  2. Logic Design
  3. unix shell command with slightly complicated commands
  • Replies 7
  • Subscribers 62
  • Views 18484
Rashed Islam
Rashed Islam over 14 years ago
 I am trying to use a 'grep' command from RTLCompile to detect a certain pattern in a generated file, and based on the outcome of the grep, do something. To be more precise, I am trying to do the following:
  1) First generate a report fiile:
           report cdn_loop_breaker > loops.txt
   2) then trying to grep that file if the tool detected any loop or not by using a unix shell command:
           grep "No loop" loops.txt
       when I try to do this unix command from rc prompt,
            shell grep "No loop" combinational_loops.txt
       it fails to perform the grep saying "Child process exited abnormally". Looks like, it cannot interpret two words "No loop".
       However, if I specify one word it can match the string properly.
Any idea how I can do this?
Thanks.
  • grasshopper
    grasshopper over 14 years ago
    Hi Rashed, this seems to be working fine for me. The message simply is telling you that the shell/exec call failed to find the expression in question hence returned a null/0 status. Here is my session rc:/> shell grep RC_VERSION hdl2gates.do set env(RC_VERSION) "v11.10-s013_1" rc:/> shell grep rc_version hdl2gates.do child process exited abnormally rc:/> shell grep -i rc_version hdl2gates.do set env(RC_VERSION) "v11.10-s013_1" rc:/> shell grep -i "set env" hdl2gates.do set env(RC_VERSION) "v11.10-s013_1" // set env(CDN_SYNTH_ROOT) /icd/rc/rc111/latest.RED/tools.lnx86 rc:/> shell grep -i "SET ENV" hdl2gates.do set env(RC_VERSION) "v11.10-s013_1" // set env(CDN_SYNTH_ROOT) /icd/rc/rc111/latest.RED/tools.lnx86 hope this helps, gh-
  • Rashed Islam
     Thanks grasshopper for your reply. I understand that it works, but how can I write a conditional to detect the loop in that file and quit? e.g.:
      if (loop_detected) {
        quit
  • grasshopper
    Hi Rashed, use the TCL 'catch' command. catch return true when its argument produces an error status so you can do something like rc:/> shell grep -i "SET ENV" hdl2gates.do set env(RC_VERSION) "v11.10-s013_1" // set env(CDN_SYNTH_ROOT) /icd/rc/rc111/latest.RED/tools.lnx86 rc:/> if ![catch {shell grep -i "SET ENV" hdl2gates.do} errMsg] { puts "Found Expression" } set env(RC_VERSION) "v11.10-s013_1" // set env(CDN_SYNTH_ROOT) /icd/rc/rc111/latest.RED/tools.lnx86 Found Expression gh-
  • Rashed Islam
     Thanks grasshopper - that worked.
    Just curious, is there a better way of detecting combinational loops in RTL Compiler?
     -Rashed
  • grasshopper
    HI Rashed, indeed there is. TIM-20 is the message RC generates when a loop is detected (provided high enough of an information_level setting). As a result you can do something like if {[get_attr print_count [find / -message TIM-20]] != 0} {
  • Rashed Islam
    You have been immensely helpful, grasshopper. I appreciate it. :)
  • grasshopper
    Hi Rashed, thanks for the kind words. I was also suggestion the following solution by another colleague if you cannot increase the information_level enough for TIM-20 to be reported redirect –var loop_ck { report cdn_loops } if [string match $loop_ck “No Loops”] { } good luck, gh-
