  2. Logic Design
  3. Need some more information about Trimmed index [CDFG-420...
  • Subscribers 61
  • Views 15309
Need some more information about Trimmed index [CDFG-420]
archive over 19 years ago
While using RTL compiler I get the following warning message. [CDFG-420]
Trimmed index 'portIn' of signal 'startT0' from 2 bits to 1 bits in file
The code for above is :
parameter PORTS = 4;
input wire [1:0]    portIn;
input wire [3:0]    cntIn;
reg [PORTS -1:0]        pauseDa;
case (cntIn)
            0: pauseDa[portIn]
I noticed that in other instances, when I used an integer instead of a binary number, it gave the same warning.
As soon as I converted 0 to 1'b0 and 1 to 1'b1, this warning was not issued any more.
In the above case, whenever, a bus was used as the index, it issues the above warning.  From the code above, we
know pauseDa can have 4 values and portIn can address 4 locations.  But the warning says trimming index to 1 bit.
There was no such problem when integers were used for indexing.  (in a for loop).  So, I modified the code as follows,
int portIn_int;
assign portIn_int = portIn;
        case (cntIn)
            0: pauseDa[portIn_int]
But I continue to get the same warning.
Trimmed index 'portIn_int' of signal 'pauseDa' from 32 bits to 2 bits
The problem is even though the RTL and netlist can be verified each time using verplex, I have to still go through the
logs to make sure that all these warnings are ok.
Alternatively, I could set:
set_attr hdl_trim_target_index false
but it mentions that the design is not optimized.  I did verify, that there is a slight increase in area with the above
setting to false.  Default is true.
Any suggestions or similar experiances are appreciated.
Amar.
Originally posted in cdnusers.org by adudyala
    Sorry,
    I put the wrong Warning number. The correct one is : [CDFG2G-617]
    Amar
    Hi Amar, just tried the following code: module debug ( input wire [1:0] portIn, input wire [3:0] cntIn, in1, output wire [3:0] out1 ); parameter PORTS = 4; reg [PORTS -1:0] pauseDa; // wire integer portIn_int; // assign portIn_int = portIn; always @(cntIn or portIn or in1) begin case (cntIn) 0: pauseDa[portIn] <= in1; endcase // case(cntIn) end // always @ (cntIn) assign out1 = pauseDa; endmodule // debug and I can see the CDFG2G-617 when I do the mod you did. In that case, it makes sense to me since integers are 32 bits and pauseDa is 2 hence the tool has to trim or else you could give up some optimizations. I noticed that your thread talks about another signal for which you do not show the code > Trimmed index 'portIn' of signal 'startT0' from 2 bits to 1 bits in file It probably is a similar issue. If you can share the code with startT0 I can probably help you out. I am using 6.2-s010, what version are you using ? take care, gh-
    Originally posted in cdnusers.org by grasshopper
