  2. Logic Design
  3. Passing Defines during read_hdl
  • Subscribers 61
  • Views 17327
archive over 19 years ago
I'm looking to see how to pass defines during the read_hdl RC command.  Below is an example.  I've tried many variations but just can't seem to get it working.
read_hdl -sv -define {tpd} -top genmemory_mp {../../common/rtl/csco_routines.v   ../rtl/genmemory_mp.v}
Originally posted in cdnusers.org by bryan
    Hi Bryan,
    tried something similar and it worked as expected. I wonder if it is something in the RTL or maybe try without the -top option. I did a man on read_hdl and it seems to indicate that -top is related with structural netlists. Since you have an `ifdef I am assuming it is not structural although not necessarily the case. I usually read_hdl everything and specify the top on the elaborate command but RC seems to do a pretty good job figuring it out by itself anyhow. Here is my short example if you find it useful:
    module define_hdl (
    input wire in, clk,
    output wire out
    reg pipe0;
    `ifdef use_neg_edge
    always @(negedge clk) begin
    pipe0 <= in;
    end // always @ (negedge clk)
    `else
    always @(posedge clk) begin
    pipe0 <= in;
    end // always @ (posedge clk)
    `endif
    assign out = pipe0;
    endmodule // define_hdl
    good luck,
    gh-
    Originally posted in cdnusers.org by grasshopper
    Well, I tried the exact same command today and it works. Not sure what was going on but none the less, problem resolved.
