  2. Logic Design
  3. LEC report additional FF
  • Replies 7
  • Subscribers 63
  • Views 22207
theodoredj
theodoredj over 14 years ago
We have a huge design with many redundant FFs.
It's impossible to clean up the RTL as they are coming from many different IP vendors.
Synopsys DC optimized out all those redundant FFs as their outputs go to nowhere. However,
LEC doesn't see this and failed on RTL VS Netlist check.
We tried to turn on and off many flatten mode options, as -seq_constant, -gated_clock, -seq_redundant, -LIB_SEQ_Redundant etc.
Nothing works.
LEC passed when we set some options in DC to keep those redundant FFs.
But we really don't want to keep them.
Any suggestions? Thank you!
  • croy
    croy over 14 years ago
     Hi
    Did you try 'analyze setup'/'set analyze option -auto'?
    Chrystian
  • theodoredj
    Hi Chrystian,
    Thanks for your reply in your previous email, it solved the problem I reported.
    However, the same issue comes out again in my current project.
    First of all, please let me refresh the issue:
    Basically there’re redundant FFs in the design, DC was able to optimize them out but LEC can’t.
    These redundant FFs cause un-equivalent for other compare points.
    I think because fan in cone of the compared point is too huge, LEC just give up at the first test vectors and claim un-equivalent because inputs are different.
    Here’s the register definition in RTL code:
       reg [7:0] ec_dma_cpu_reg [511:0];
    Here’s DC log: As you can see, some bits are optimized out as early as when DC reads in the RTL.
    |                    Register Name                    |   Type    | Width | Bus | MB | AR | AS | SR | SS | ST |
    |                 ec_dma_cpu_reg_reg                  | Flip-flop |   8   |  Y  | N  | Y  | N  | N  | N  | N  |
    |                 ec_dma_cpu_reg_reg                  | Flip-flop |   7   |  Y  | N  | Y  | N  | N  | N  | N  |
    |                 ec_dma_cpu_reg_reg                  | Flip-flop |   6   |  Y  | N  | Y  | N  | N  | N  | N  |
    |                 ec_dma_cpu_reg_reg                  | Flip-flop |   4   |  Y  | N  | Y  | N  | N  | N  | N  |
    Here’s the LEC unmapped point report:
    Unmapped point (not-mapped):
      (G)   58700      Z    /u_ec_dma_cpu_reg/ec_dma_cpu_reg[77][7]
      (G)   58701      Z    /u_ec_dma_cpu_reg/ec_dma_cpu_reg[77][6]
      (G)   58702      Z    /u_ec_dma_cpu_reg/ec_dma_cpu_reg[77][5]
      (G)   58703      Z    /u_ec_dma_cpu_reg/ec_dma_cpu_reg[77][4]
    Here’s the diagnose report:
    // Command: diagnose 1318 -golden // gate XO_CPU_HRDATA[31]
    Diagnosis for Non-equivalent key points:
      (G) + 1318       PO   /XO_CPU_HRDATA[31]
      (R) + 1318       PO   /XO_CPU_HRDATA[31]
    There is an extra but mapped key point in this logic cone
              ID        Type                Name
       (G) + 1657      'DFF'               /u_ec_dma_cpu_reg/r_queue_read_ptr_reg[4]
    There is an extra unmapped key point in this logic cone
              ID        Type                Name
       (G)   58700     'Z':'NET'           /u_ec_dma_cpu_reg/ec_dma_cpu_reg[77][7]
    Non-equivalent signal and its error candidates
         ID (R)       Type            Likelihood  Name
         1318         'PO'                        /XO_CPU_HRDATA[31]
    ------- Candidates -------------------------------------------------------------
    1:   259049       szd_sbufx20     1.00        /u_ec_dma_cpu_reg/U43505
    2:   259052       szd_sbufx14     1.00        /u_ec_dma_cpu_reg/U28294
    3:   259053       szd_sivx8       1.00        /u_ec_dma_cpu_reg/U28249
    4:   259056       szd_sbufx14     1.00        /u_ec_dma_cpu_reg/U28298
    5:   259057       szd_snr3x16     1.00        /u_ec_dma_cpu_reg/U42294
    6:   259059       szd_sbufx20     1.00        /u_ec_dma_cpu_reg/U43440
    7:   259060       szd_sbufx20     1.00        /u_ec_dma_cpu_reg/U43259
    8:   259061       szd_sbufx4      1.00        /u_ec_dma_cpu_reg/U15466
    9:   259070       szd_sivx6       1.00        /u_ec_dma_cpu_reg/U34475
    10:  259071       szd_sbufx10     1.00        /u_ec_dma_cpu_reg/U34472
    Here’re the options I used in my script:
    set flatten model -nodff_to_dlat_zero
    set flatten model -nodff_to_dlat_feedback
    set flatten model -seq_constant
    set flatten model -gated_clock
    set flatten model -NOLATCH_Fold
    set flatten model -LATCH_Transparent
    set mapping method -name first
    set wire resolution wire -both
    add ignore rtlcheck -all
    Any suggestions?
    Thank you.
    Jun Dong
  • AyCaramba
    AyCaramba over 14 years ago
    You have type 'Z' as an unmapped in the golden. By default that's how LEC treats undriven signals. DC would ground them. Are you using 'set undriven signal 0 -golden' so LEC matches DC?
  • theodoredj
    It works, thank you.
    Jun Dong
  • tstark
    tstark over 14 years ago
    Glad to read that your design is now EQ.
    Please note that
    is a global constraint and can change the design behavior from RTL simulations. If the RTL has undriven signals, ideally they are fixed in the RTL to be driven. If that is not possible, it is safer to drive specific signals rather than globally forcing them.
    If driving unconnected signals is temporarily needed for an unfinished design then echo statements in the dofile can help warning the user that temporary constraints have been added.
    There is a nice Solution article on this
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11345198
     It makes for an interesting read.
    -ps
  • theodoredj
    This is a very interesting article, thank you very much!
    I do have a question regarding the undriven signal definition.
    I noticed that some unused ports on hierarchy module are also defined as undriven signal because they are defined as output ports.
    Is there anyway to filter them out?
    Thank you.
    Jun Dong
  • affaqq
    affaqq over 14 years ago
    I am on vacations so might not be able to respond timely. I will get back to work from 2nd Sept, 2012.
    Ciao!
    Affaq Qamar
    Mob:+3280294862
