  2. Logic Design
  3. RTL Compiler -- clock latency
  • Subscribers 62
  • Views 2151
amitram
amitram over 14 years ago
1.  Can someone please explain what is the exact meaning of clock latency.
2. What is the meaning of the following RC scripts
     1. path_adjust   -from  clk2  -name latency1  -delay  -30
     2. path_adjust   -to   clk2    -name latency2   -delay   30
where :-   one pin named "clk2" is the internal clock source pin of the PLL and the other clk2 is the clock port of some block.
why is the latency specified in terms of negative time (-30ps). ?
  • grasshopper
    grasshopper over 14 years ago
    Hi Amitram, there is a nice write-up over here http://www.edaboard.com/thread130000.html I would go further to say that while modelling latency using path_adjust works, there is an SDC command set_clock_latency intended for exactly that purpose which is probably a better way to model. path_adjust positive and negative simply means adjusting the path by adding or subtracting a given delay number hope this helps, gh-
