  2. Logic Design
  3. I am using FreePDK45nm library. I couldn't synthesise a...
  • Subscribers 62
  • Views 1651
I am using FreePDK45nm library. I couldn't synthesise a register file.
Thommandram
Thommandram over 14 years ago
I am doing a microprocessor design. Sap-1 architecture. I've attached the verilog codes of this microprocessor here.
The problem is.. I couldn't finish the logic synthesis of  the processor. During synthesis in the Cadence RTL compiler-Physical, the the synthesis stops at one point. At this point, the gui window status bar shows "computing design", and the terminal window shows "accessing module mem16K or reading varible mem" But the software gets hanged at this point.
The problem maybe with the memory/register file structures, I'm not sure. I want to know whether the library FreePDK45nm might be the problem (I've tried a Nangate library too!, it isn't working with that either.).
Do you think the FreePDK45nm has the correct memory cells to implement a register file? If so, What else would be the problem in synthesizing a register file.
code for the memory block or the RAM in the microprocessor.
module mem16K(data, address, CS, WE, OE);
  parameter wordSize = 8;
  parameter addressSize = 4;
  inout [wordSize-1:0] data;
  input [addressSize-1:0] address;
  input CS, WE, OE;
  reg [wordSize-1:0] dataReg;
  reg [wordSize-1:0] memory [0:1<<addressSize];
  // attach a tristate buffer to the databus
  // if OE is active(low), connect datawires to the dataRegisters
  // if OE is inactive(high), set datawires to high impedance for input
  assign data = (!OE && WE && !CS)?dataReg:8'hzz;
  // the reason cs is not put in the condition is
  // internal wires are in accordance with databus
  // but the data is not stored in memory so no problem
  initial
  begin
/* execution of a small program */
memory[0] = 8'h09; // LDA 9H
memory[1] = 8'h1A; // ADD AH
memory[2] = 8'h1B; // ADD BH
memory[3] = 8'h2C; // SUB CH
memory[4] = 8'hE0; // OUT
memory[5] = 8'hF0; // HLT
  // dataReg = 8'h00;
// Instructions must be stored here before running SAP1
// memory[0] = 8'b00001011; // LDA 08H ( ie: load contents from memory loc. 8 (B8) to acc)
// memory[1] = 8'b11100000;
// memory[2] = 8'b00011000;
// memory[3] = 8'b11100000;
//memory[2] = 8'b00001010;
//memory[3] = 8'b00001011;
//memory[2] = 8'b00011001; // ADD 09H
//memory[2] = 8'b00011011;
// data contents of memory
memory[9] = 8'h01;
memory[10] = 8'h02;
memory[11] = 8'h03;
memory[12] = 8'h04;
  end
  always @(WE or OE or CS)
  begin
    // incase of active(low) CS and active(low) WE
    if (!CS && !WE)
    begin
      #1;
      memory[address] = data;
//      $display(data);
    end
  end
  begin
      if (!OE && !CS && WE)
        dataReg = memory[address];
  end
endmodule
do you see any problem with this block? But I am able to simulate this code in the xilinx ise.. I'm just not able to do the synthesis.. help!!
Thanks in advance.
submit to forum.doc
  • grasshopper
    grasshopper over 14 years ago
    HI Thommandram, looks like you are reading the behavioral model of the register files which is intended for your functional simulations. For synthesis, you need a liberty model (.lib) for them gh-
