  2. Logic Design
  3. How can I remove module before writing whole netlist ou...
  • Subscribers 62
  • Views 15921
How can I remove module before writing whole netlist out
Maso
Maso over 14 years ago
I have a design top module "top". It have a sub module "add_sub".
I will write out whole netlist for top, but I don't want to write out add_sub.
How can I do this?
 Thanks a lot.
  • bmiller
    bmiller over 14 years ago
     In RC, you can do the following:
    foreach i [get_attr instances [find / -subdesign add_sub]] {
        set_attr unresolved true $i
    write_hdl > top.vg
    The above script finds all instances of add_sub, and sets an "unresolved" attribute on each instance.  This TCL could, of course, be simplified if there is only one instance of add_sub.
    write_hdl will now omit the add_sub module from the netlist.
  • Maso
    Hi bmiller,
    It works.
    Thanks a lot for your help.
    |         |           2012/04/02 下午  |
    |         |           08:59            |
    |         |           Please respond to|
    |         |           ld_forum         |
      |To:maso_chen@tsmc.com        |
      |cc:        |
      |Subject:Re: [Logic Design Forum] How can I remove module before writing whole netlist out                                                 |
    write_hdl > top.vg
