  2. Logic Design
  3. remove_assigns
  • Subscribers 61
  • Views 17485
remove_assigns
archive over 19 years ago
v07.10-p004_1 says to me that remove_assigns command will be obsolete in the future, because Encounter will be able to process assign statements in the netlist. However we use 3rd party backend tools which need a netlist without any assign statement.
I have following code in RTL:
assign y = x;
but the netlist still has it that:
assign y = x;
I have tried several combinations for remove_assigns but not successes. This command does not clean assigns completely.
Also, the removed assign statements are replaced with following instance names:
  bfx2 rm_assigns_buf_out_0_0(.A (in_1[0]), .Z (out_0[0]));
Is there any attribute in Cadence how to control the instance names like this?
Thanks...
Originally posted in cdnusers.org by sporadic crash
    Often RC can't remove assign because of "preserve" attribute
    Try somthing like this:
    # Reset existing preserve attributes (set preserve attribute to false)
    set save_ui_respects_preserve [get_attribute ui_respects_preserve /]
    set_attribute ui_respects_preserve false /
    remove_assigns
    # Restore setting
    set_attribute ui_respects_preserve $save_ui_respects_preserve /
    Originally posted in cdnusers.org by Stalker
    Hi Stalker,
    extremely sorry for late answer. I was busy with some other stuff.
    I was asked by Cadence FAE to use /etc/synth/rc/remove_assigns.tcl which "emulates" the obsolete command for 7.x releases, because 7.x does not support it any more.
    Having used this command in the script, I have seen that all buffers inferred have the [b]preserve[/b] attribute of "size_ok". Their inherited_preserve also. All the parent modules are either top-level or in the form of csa_tree_addxxx in instance name. CSA ones are I think synthetic operators. However these parent modules do not have preserved attribute of "size_ok", instead, "false".
    Just because of the reason I could not rename the buffer instance names. I wonder why RTL Compiler puts inferred buffers to remove assigns into preserve of "size_ok"?
