  2. Logic Design
  3. How to calculate speed for each path_group in RTL Compi...
  • Subscribers 62
  • Views 15393
How to calculate speed for each path_group in RTL Compiler
Maso
Maso over 14 years ago
 I want to write script to calculate speed for each path_group defined in advance.
Does any body can give me some ideas to do this?
 Thanks a lot.
  • grasshopper
    grasshopper over 14 years ago
    Hi Maso,
     you probably want something along lines of
    proc GetCgCritPeriod { args } {
    # Parse command line switches
    # return an error if incorrect arguments are given
    switch -- [parse_options [calling_proc] {} $args \
          "-mode dos(mode) specify which mode to report for when mutli-mode design (default is worst slack mode)" modeName \
          "srm cost group to provide critical period information for" obj ] {
      -2 { return }
      0 { return -code error }
    if {[regexp {no_value} [get_attr slack $obj]]} { return "N/A" }
    array set endInfo [lindex [get_attr timing_info [get_attr critical_endpoint $obj]] 0]
    if {[string match "unclocked" [lindex $endInfo(capture) 0]]} { return "Unclocked" }
    return [format "%.2f" [expr {[get_attr period [lindex $endInfo(capture) 0]] / [get_attr divide_period [lindex $endInfo(capture) 0]]}]]
        proc GetCgCritFreq { args } {
      -2 { return }
    if {[regexp {Unclocked} [eval GetCgCritPeriod ${obj}]]} { return "Unclocked" }
    set cgSlack [get_attr slack $obj]
    return [format "%.1f" [expr {1000000 / ([eval GetCgCritPeriod ${obj}] - ${cgSlack})}]]
    Furthermore, you there is a nice applet for it that you can use
    applet load generate_repport
    generate_report....
    which will generate a nice HTML report for you including this information. Don't confuse generate_report with generate_reports which is text based
    gh-
  • Maso
    Hi grasshopper,
     I have got what I want from your script.
    It's very useful for me.
     Thanks a lot for your help.
