  2. Logic Design
  3. SDF file and HOLD time and SETUP time
  • Subscribers 61
  • Views 17514
archive over 19 years ago
I am just starting using the nano encounter tool. I just wonder if the sdc file we give to the encounter tool should be the same as SDC file we give to the RTL compiler?
I want to connect my synthesized block to a memory with specific setup hold time. Does anyone has an idea how to give the encounter tool the specific setup time and hold time? how to put a constrain on its output and input port for setup and hold time?
Houman
Originally posted in cdnusers.org by houmanh
    Houman,
    It sounds like you are trying to model the external environment around your chip. This would typically be done using the set_input_delay and set_output_delay SDC constraints. Both of these have a -min and -max option that will allow you to accurately model the setup and hold time to/from your memory block. Be advised that RTL-Compiler will not use the -min constraints but will save them and write them out for SOC-Encoounter. The reason for this is that RC does not do any hold time fixing as this is best left until after P&R.
    Regards
    Originally posted in cdnusers.org by jflieder
    Thanks fo rthe information.
    Now my setup time is fine. But I still have problem with hold time.
    The problem is that the encounter tool disregard the hodl time I define for specific port in the sdc file using the command below:
    set_output_delay -clock [get_clocks {clk}] -min 0.4 [get_ports {mem_d}]
    where I want to have a 400ps hold time.
    Thanks.
    Houman
