  2. Logic Design
  3. No Hold Time Constrains Read In
  • Subscribers 61
  • Views 14925
archive over 19 years ago
I have a sdc file in which defined the ports hold time and setup time like :
set_output_delay -clock [get_clocks {clk}]  -min 5 -add_delay [get_ports {mem_d}]  //for hold time
set_output_delay -clock [get_clocks {clk}]  -max .3 [get_ports {mem_d}]                  //for setup time
but when i run the nano encounter, I get the message:
No Hold Time Constrains Read In.
As It appear the encounter read setup time and do setup fix, but it doesn't read the hold constrain.
I also tried to change the -min value but I got similar results for hold WNS(which shows the tool didn't respect the hold time)
Can anyone help on this.
Houman
Originally posted in cdnusers.org by houmanh
    I didn't get a chance to test but you either need to change the order of the constraints or need to remove the -add_delay as the constraint are not for the same timing type. The -add_delay is typically for associating a timing with a second clock.
    Originally posted in cdnusers.org by evenditti
