  2. Logic Design
  3. Checking equivalence of buffer trees
  • Subscribers 62
  • Views 16532
BufferTree
BufferTree over 14 years ago
I have two netlists, a revised and a golden, both containing a mesh/tree hybrid comprised entirely of inverters. There are multi-driven nets and bidirectional ports galore, but the input to the tree is a pin/net called "clk", and the output is a net called "GCK".
When I load these two netlists into Conformal, I get this message when attempting to run a compare:
 LEC> compare
// Command: compare
// Nothing to compare. 'Add compared points' first.
 When attempting to add a compare point, I get:
 LEC> add compared points clk -golden
// Command: add compared points clk -golden
These mapped points are not compared:
  (G) + 1   PI   /clk
  (R) + 1   PI   /clk
LEC> add compared points clk -revised
// Command: add compared points clk -revised
// Warning: 'clk' in Revised is not a mapped point
// Warning: No compared point is added
When attempting to add a mapped point, I see:
  (G) + 1   PI   /clk
  (R) + 1   PI   /clk
Is there a guide to comparing netlists without sequential elements?
If not, could someone walk me through the basics of comparing netlists without sequential elements, and the creation of compare points?
I'm more than happy to go read up on this, but the  "Mapping Modifications" section of the User Guide wasn't helping me.
Thanks in advance!
~BufferTree
  • tstark
    tstark over 14 years ago
    Hi.
    A very basic example dofile is as follows. You may not need some of the options but this is a good start for much designs.
    read library -verilog -replace -both <lib_files>
    read design -verilog -golden <design_files>
    read design -verilog -revised <design_netlist>
    report design data
    report black box -detail
    add pin constraint 0 scan_en  -golden/revised
    add ignore output  scan_out -golden/revised
    set flatten model  -seq_constant
    set flatten model  -gated_clock
    set analyze option -auto
    set parallel option -threads 4
    set system mode lec
    add compared point -all
    compare
    It seems like your main problem is with "add compared points". You are only trying to compare the input clk in your design. This isn't adding the needed compare points to your design.
    There is this new Web Interface feature (11.1) that for me has a lot of good information. You may try that or the LEC Jumpstart which is a good starting point.
    > set web on
    http://tinyurl.com/cadence-rak   (look for jumpstart).
    -stark
