  2. Logic Design
  3. typedef enum in SV
  • Subscribers 61
  • Views 15557
typedef enum in SV
archive over 19 years ago
Hi there,
I ve written a module by using typedef enum as shown below and it cannot be synthesis. Syntax Error stated :
- Expecting module level statement
- Expecting target variable, got p_state - Misspelling?
- Expecting radix character (one of b, o, h, or d) or unsized single bit literal (one of '1, '0, 'x, 'z)
Can anyone give me some advice on this? thank you very much.
typedef enum logic ?:0]{
 Idle = 0,
 Fetch = 1,
 Exe = 2
} state_type;
state_type p_state, n_state;
always @ ( posedge clk or negedge nreset)
begin
  if (~nreset)
    p_state = state_type'(Idle);
  else if (clk)
    p_state = n_state;
end
Originally posted in cdnusers.org by SHL
    Hi SHL,
    would you mind posting the error with its error code from the log ?
    In RC your example seems to work. Are you sure you are using the -sv
    switch when reading the HDL ?
    thanks,
    gh-
    Originally posted in cdnusers.org by grasshopper
