  2. Logic Design
  3. Driving of reset line - order of magnitude difference between...
  • Subscribers 61
  • Views 3278
Driving of reset line - order of magnitude difference between RC & PrimeTime
archive over 19 years ago
Dear all,
I am running into a weird problem with rtlcompiler on which I need some expert advice :-)
In my design I have a reset line (asynchronous) which is connected to different blocks. In every block the signal is inverted and then passed to a bunch of RN-pins. The problem that I am encountering is that rc selects the smallest available inverter to drive these pins. A timing report through the inverter does not show any problem. In the example below the inverter g1529 only adds a delay 163ps while it is loading 159 reset pins.
When performing a timing analysis with primetime the delay is found to be 6.25ns. I assume this value is correct?
When I export the net loads with write_set_load I see that the net loaded by the inverter has a load of 0. Almost all other nets (even the ones with only a couple of loads attached) have a load > 0.
Probably this is something very simple, I am quite new to rtlcompiler ;-)
Michael
RTL Compiler:
         Pin                   Type      Fanout  Load Slew Delay Arrival
                                                 (fF) (ps)  (ps)   (ps)
(clock virtual_clock)        launch                                    0 R
                             latency                       +1200    1200 R
(in_del_1)                   ext delay                     +1000    2200 F
mem_select[0]                in port          3   6.3    0    +0    2200 F
g519/A                                                        +0    2200
g519/Y                       INVX1MTH         2   8.3  207  +125    2325 R
g517/A0                                                       +0    2325
g517/Y                       AO22X4MTH      100 119.2 1222  +878    3203 R
g516/B                                                        +0    3203
g516/Y                       NAND2BXLMTH     22  28.6 1340 +1163    4366 F
cell/reset
  inst_decoder/reset
    g1529/A             <<
    g1529/Y             (i)  INVX1MTH       159   0.0    0  +163    4529 R
    reg_IR_ID_reg[9]/RN      DFFRHQX4M                        +0    4529
Timing slack :  UNCONSTRAINED
Start-point  : mem_select[0]
End-point    : cell/inst_decoder/reg_IR_ID_reg[9]/RN
rc:/> get_attribute net /designs/base/instances_hier/cell/instances_hier/inst_decoder/instances_comb/g1529/pins_out/Y
/designs/base/instances_hier/cell/instances_hier/inst_decoder/nets/n_1617
rc:/> get_attribute num_loads /designs/base/instances_hier/cell/instances_hier/inst_decoder/nets/n_1617
159
PrimePower:
  Point                                                   Incr       Path
  clock virtual_clock (rise edge)                         0.00       0.00
  clock network delay (ideal)                             1.20       1.20
  input external delay                                    1.00       2.20 f
  mem_select[0] (in)                                      0.00       2.20 f
  g519/Y (INVX1MTH)                                       0.12       2.32 r
  g517/Y (AO22X4MTH)                                      0.89       3.21 r
  g516/Y (NAND2BXLMTH)                                    1.17       4.38 f
  cell/reset (opn_base)                                   0.00       4.38 f
  cell/inst_decoder/reset (decoder)                       0.00       4.38 f
  cell/inst_decoder/g1529/Y (INVX1MTH)                    6.25      10.63 r
  cell/inst_decoder/reg_IR_ID_reg[19]/RN (DFFRHQX8MTH)
                                                          0.00      10.63 r
  data arrival time                                                 10.63
Originally posted in cdnusers.org by denil
    since RTL_compiler is a synthesis tool, it makes certain assumption and high fanout net (ideal net with no wire delay) is one of them. In this case, it treated the RESET net as a high fanout ideal net and it assumed the net will be re-buffer in the p&r tool so no buffer tree was built for the net and also it assumed a wire delay of zero. I think you can change this behaivour by some variable (control min fanout #).
    li siang
    Originally posted in cdnusers.org by lisiang
    Hi Li Siang, thanks for you advance!
    Apparently I am doing something wrong in my p&r scripts, since the cell is not replaced by a bigger one. I will look into it.
    In meanwhile I tried to set the max_fanout for the whole design to 10 by:
    set_attribute max_fanout 10 /designs/base
    After synthesizing the design again the same not cell is used and still has as many reset pins connected to it. When I execute the fanout command on the output pin of the not, I get a list of over 100 pins connected to it. What is also weird is that when I check the design rules that it does not show any violation of max_fanout:
    rc:/> get_attribute max_fanout /designs/base
    10.000
    rc:/> report design_rules /designs/base
    Tracing clock networks.
    Levelizing the circuit.
    Computing net loads.
    Computing delays.
    Computing arrivals and requireds.
    Initializing DRC engine.
    Generated by: Encounter(r) RTL Compiler v06.20-s027_1
    Generated on: Oct 22 2007 09:54:47 AM
    Module: base
    Technology libraries: ...
    Operating conditions: ...
    Interconnect mode: ple
    Max_transition design rule: no violations.
    Max_capacitance design rule: no violations.
    Max_fanout design rule: no violations.
    Any idea why this would be?
    Thanks for your help!
    Michael
    Hi Michael,
    I believe RC idealizes clock nets and async reset pins since this are usually large fanout and much better handled in P&R. If you want to change this behavior I think there is an attribute to control that but cannot remember the name off the top of my head.
    The max_fanout attribute will not have any effect on these nets because they were idealized.
    gh-
    Originally posted in cdnusers.org by grasshopper
