  2. Logic Design
  3. Gate-leve sim, sdf back annotation warnings
  • Subscribers 61
  • Views 23192
archive over 18 years ago
I am running sdf-back-annotated Gate-level sims. During ncelab, I see the following warnings: 1. ncelab: *W,SDFNEP: Failed Attempt to annotate to non-existent path (IOPATH CP Q) of instance :DUT0.u_core.u_cfg.u1_xxxx_apb.bus_sync1.clk_gate_dest_bus_reg.latch of module c065std_cell_icgX10 . The corresponding line (line 329587) in the SDF file is DELAY (ABSOLUTE (IOPATH CP Q (0.173::0.456) (0.183::0.486)) ) ) When I check the verilog for the standard cell library for the cell in question I see the following: specify (CP => Q) = (`c065std_cell_icgX10_CP_F_Q_F, `c065std_cell_icgX10_CP_R_Q_R); $setuphold(posedge CP, posedge TE, `c065std_cell_icgX10_TE_CP_SETUP, `c065std_cell_icgX10_TE_CP_HOLD, Notifier, ,EX ,CPdly, TEdly); $setuphold(posedge CP, negedge TE, `c065std_cell_icgX10_TE_CP_SETUP, `c065std_cell_icgX10_TE_CP_HOLD, Notifier, ,EX ,CPdly, TEdly); $setuphold(posedge CP, posedge E, `c065std_cell_icgX10_E_CP_SETUP, `c065std_cell_icgX10_E_CP_HOLD, Notifier, ,TEX ,CPdly, Edly); $setuphold(posedge CP, negedge E, `c065std_cell_icgX10_E_CP_SETUP, `c065std_cell_icgX10_E_CP_HOLD, Notifier, ,TEX ,CPdly, Edly); $width(negedge CP, `c065std_cell_icgX10_CP_PWL, 0, Notifier); endspecify Looking at this there does seem to be a path from CP -> Q. Can someone tell me why I still see this warning? 2. For the same module as above, I see the following warning ncelab: *W,SDFNSB: Attempt to annotate specify block data of instance :DUT0.u_core.u_cfg.u1_xxxx_apb.bus_sync1.clk_gate_dest_bus_reg.latch of module c065std_cell_icgX10, which has no specify block . The corresponding section in the SDF file (line 329591) is: (TIMINGCHECK (WIDTH (negedge CP) (0.120::0.120)) (SETUP (posedge TE) (posedge CP) (0.162::0.162)) (SETUP (negedge TE) (posedge CP) (0.084::0.084)) (SETUP (posedge E) (posedge CP) (0.295::0.295)) (SETUP (negedge E) (posedge CP) (0.246::0.246)) (HOLD (posedge TE) (posedge CP) (-0.115::-0.115)) (HOLD (negedge TE) (posedge CP) (-0.071::-0.071)) (HOLD (posedge E) (posedge CP) (-0.128::-0.128)) (HOLD (negedge E) (posedge CP) (-0.082::-0.082)) ) Looking at the afore-mentioned "specify" block can anyone help me understand the reason for this second warning? 3. Also the specify block contains $setuphold in an extended format. Can someone please explain the four fields after "notifier"? Thanks in advance Vishnu
Originally posted in cdnusers.org by raajaavishnu
    Not sure what's the problem with the CP->Q arc, what are the specparams for:
    In problem #2, ncsim expects a combined setuphold check arc. RC only writes them separately, there's no option to merge setuphold check in the current 7.1 version. You might want to try the workaround using write_sdf in bgx_shell (in the same RC installation).
    Originally posted in cdnusers.org by synthman
    I can't speak for RC's switches and features, but I can shed some light on SDF annotation from a simulation point of view.  There is always great confusion over this.  Also note that you can have negative values with SETUPHOLD (and RECREM), but you can only have positive values for SETUP and HOLD.  NCSim does a nice job of simulating the negative timing checks (it's just a time reference).  Sometime you'll see something like "timing yada yada from here to there cancelled" in the simulation log, this is OK, it's just a warning to tell you that a different path fullfilled the timing.  Below are some notes on SDF annotation for simulation.
    SDF file can be more general than Verilog
    For instance if SDF has:
    (HOLD (posedge resetb) (posedge phi) (-0.003:-0.003:-0.003))
    and the Verilog has:
    $hold(posedge phi &&& enableRRV, posedge resetb, 0, notify_reg);
    the SDF is giving a general case, that posedge phi can annotate to a posedge phi + some condition.
    The other case, Verilog being more general cant work because there would be confusion of exactly what timing to implement.
    If SDF says annotate BLUE and the Verilog has a LIGHT BLUE flavor, then it will annotate.
    If Verilog says LIGHT BLUE, then the SDF must have a LIGHT BLUE to annotate
    Originally posted in cdnusers.org by tmackett
