  2. Logic Design
  3. dsn-files
  • Subscribers 62
  • Views 14989
dsn-files
wschira
wschira over 14 years ago
 Hello everyone,
can someone me show the structure of dsn-files or a place I can find them? The background is the following: I' ve build a project in Capture and then created a netlist. But on this procedure something seems to be going wrong. I could'nt load  the original dsn-file nor the dbk-file anymore. It came with some strange error messages like "access to address xxx not possible, access violation". But the xxx is much greather then the complete file. I compared the original and the security copy and they look to be the same. So I think there is either a jump everywhere in the program or the Capture find no end of the program. I loaded the dsn-file in an Hex-Editor and compared it with an existing dsn-file, which can be load (is ok) in Capture. I saw, that in the working file is a suite of records of the design (parts, connection etc) and on the end is a part (cryptic), which doesn' t exist in the corrupted file.So maybe I could recover the file if I knew exactly the file structure.
