  2. Logic Design
  3. How do you find the driving cell?
  • Subscribers 61
  • Views 17627
archive over 18 years ago
All -
How do you get the driver cell name of a net or hierarchical pin? I have tried the following commands -
fanin -structural -max_logic_depth 1 [get_attr drivers [find / -net XX]]
gives me the input pins of the fanins. I want to get the hierarchical name of output pin of the driving cell in question.
Any suggestions?
Sanjay
Originally posted in cdnusers.org by ssunder@sioptical.com
    Hello Sanjay,
    You specify only 1 logic depth of a driver pin, which is an output pin, that's why so see the input pins. Try max_logic_depth of 2.
    Originally posted in cdnusers.org by synthman
    Synthman -
    I don't think you want a logic depth of 2 here. If the result of [get_attr drivers] is already a leaf driver, then you already have your result. However if [get_attr drivers] returns a hierarchical boundary pin (and I'm assuming this is the tricky case you need to handle), then you want to get the fanin with the max PIN depth set to 1. Below is some code to help distinguish between the hierarchical boundary pin case and the trivial case.
    Hope this helps...
    - Denis
    proc is_hier_boundary {pin} {
    return [expr {[basename [dirname [dirname [dirname $pin]]]] eq "instances_hier"}]
    proc leaf_driver {net} {
    set drvrs [get_attribute drivers $net]
    if {! [llength $drvrs]} {
    return [list]
    # get the first driver of the net (in case there are many)
    # could loop over all drivers instead
    set drvr [lindex $drvrs 0]
    if {[is_hier_boundary $drvr]} {
    # this is a hierarchical boundary, trace to find the leaf driver
    return [fanin -structural -max_pin_depth 1 $drvr]
    # the net is already driven by a leaf driver
    return $drvr
    Originally posted in cdnusers.org by go_rc
    Many thanks, this is what I was looking for.
    Sanjay
