  2. Logic Design
  3. RTL Compiler, Min Libraries and CPF
  • Subscribers 62
  • Views 16975
moogyd
moogyd over 14 years ago
For synthesis (RTL compiler) I define a worst case libraries read_cpf -libraries, and in the CPF I use
define_library_set -name my_lib_set _librares {libA_slow.lib libB_slow.lib libC_worst.lib}
 i.e. I load multiple worst case librarie (there are actually about 15, from different vendors)
I then export the CPF for the backedn. This works, but....
My backend engineer  is complaining that the CPF file does not contain the min libraries.In principle, I just add then in the same way, but I need RTL compiler to ignore the min libraries.
How do people usually manage this issue ?
Thanks for suggestions/links
Steven
  • grasshopper
    grasshopper over 14 years ago
     You have 2 choices. If using golden CPF as source to both RC and EDI, you can do
    set_cpf_version 1.1
    define_library_set -name wcTim -libraries [concat $stdcell(timing,$pvt(cell,wcTim)) $memory(timing,$pvt(mem,wcTim))]
    define_library_set -name wcPow -libraries [concat $stdcell(timing,$pvt(cell,wcPow)) $memory(timing,$pvt(mem,wcPow))]
    if {[regexp -nocase {/(edi|encounter)$} [info nameofexecutable]]} {
        define_library_set -name bcTim      -libraries [concat $stdcell(timing,$pvt(cell,bcTim))  $memory(timing,$pvt(mem,bcTim))]
        define_library_set -name typ        -libraries [concat $stdcell(timing,$pvt(cell,typ))    $memory(timing,$pvt(mem,typ))]
    so certain library sets will only be enabled when read by tools of your choice
    If relying on RC generated CPF for downstream tools you can ready everything in and then in RC you can remove them or set avoids/dont_use in all cells from those set along the lines of
    set_attr avoid true *bcTim*/*
    gh-
  • Maheshnb
    Maheshnb over 13 years ago
     Hi steven ,
          I have a same type of problem,
    i have written a code for inverter chain and synthesized using slow and fast lib sepaerately,which represents slow path and fast path helpful in timing analysis.
    problem is how can i use this fast lib and slow lib together so that me inverter chain should select perticilar cells from slow lib for slow path and perticular cells from fast lib for fastpath simulataneously in the same module.
    Please help in this regard.
    mahesh
    9739436239
  • grasshopper
    grasshopper over 13 years ago
     The solution provided should address your issues. Please let us know if it does not and provide additiional information on the issue you are seeing. In the context of EDI, you can also provide timing information through your view definition. Remember synthesis only requires a subset of the information needed for signoff analysis in most cases so it is not unusual for the P&R and signoff steps to add additional information needed such as hold analysis libraries, noise margins, etc.
    gh-
