  2. Logic Design
  3. few ques ..
  • Subscribers 61
  • Views 14718
few ques ..
archive over 18 years ago
I just started using RTL compiler and need some ques answered / confirmed . Following are the things i gotta do . Each query is followed by the thing that i figuered out- 1. report timing b/w all inputs and outputs -- report timing -endpoints -- OR -- report timing -from [all::all_inps] -to [all::all_outs] 2. max frequency for the block -- 3. netlist hierarchy -- ungroup -flatten Thanks
Originally posted in cdnusers.org by dhruv86
    Hi dhruv86,
    your message is unfortunately a little too brief hence I am not exactly sure what you were looking for but will take a stab:
    1 - report timing b/w all inputs and outputs -- report timing -endpoints -- OR -- report timing -from [all::all_inps] -to [all::all_outs]
    report timing -endpoints display the slack to all endpoints in the design. Does not sounds like what you want
    report timing -from [all::all_inps] -to [all::all_outs] display the worst path between inputs and outputs
    not sure what your needs are but you may want to do something like this instead
    report timing -from [all des inps] -to [all des outs] -num_paths N
    the all des syntax is a little cleaner and if you do -h there is a bunch of useful options there. The -num_paths is assuming you
    do not only want the worst guy but a number of them
    2 - max frequency for the block
    foreach clk [find / -clock *] { report timing -to $clk }
    This will display the WNS to each clock and then it is simple math to convert from period to frequency
    3 - netlist hierarchy -- ungroup -flatten
    Not sure what you want to do here. ungroup -flatten will remove all the hierarchy from the design. Usually that is not desirable
    since it limits the tools ability to do resource sharing and the such. If all you want is a report you can simply use
    report area
    or
    report hierarchy
    good luck,
    gh-
    Originally posted in cdnusers.org by grasshopper
