  2. Logic Design
  3. Step-Down Switching Regulator Controller
  • Subscribers 61
  • Views 14511
archive over 18 years ago
 FEATURES
Operation Voltage up to 15V.
Simple Voltage-Mode PWM Control.
Fast Transient Response.
2V and 1.3V ± 2% Feedback Voltage Reference Option.
Adjustable Current Limit without External Sense Resistors.
200KHz Free-Running Oscillator.
Short-Circuit Protection with Low Short Circuit Output Current.
 APPLICATIONS
Power Supply for Motherboard VGTL (1.5V Output)
Power Supply for Motherboard VI/O.
High-Power 5V to 3.xV DC/DC Regulators.
Low-Voltage Distributed Power Supplies.
 DESCRIPTION
The [url=http://www.chinaicmart.com/suppliers/119/AIC1579.html]AIC1579[/url] is a high-power, high-efficiency voltage-mode switching regulator controller for
motherboard VI/O power supply applications.Designed to drive an N-channel MOSFET in a
standard buck topology, the AIC1579 features a high voltage CMOS output driver, short-circuit
protection, and 8-pin package.
An external 4-bit Digital-to-Analog Converter (DAC) can be used along with the AIC1579 to
adjust the output voltage from 2.0V to 3.5V in 0.1V increments. Table 1 on the following page
specifies the corresponding output voltage for 16 combinations of DAC inputs as in the typical
application circuit.
The 200KHz switching frequency allows for using small external components while maintaining high conversion efficiency. The 11MHz bandwidth and 6V/µS slew rate of the error amplifier ensures high converter bandwidth and fast transient response.
The AIC1579 provides adjustable overcurrent and short-circuit protections by sensing the output current across the on resistance of the external N-channel MOSFET rather than an external low value sense resistor.
The AIC1579L provides lower reference voltage (1.30V) than the default (2.00V, AIC1579) for
lower VOUT requirement.
Originally posted in cdnusers.org by Cristinalee
