  2. Logic Design
  3. Potential multiply-driven net (corrected typesetting)
  • Subscribers 61
  • Views 13438
archive over 17 years ago
I have the following interfaces for two submodules module comparator7(a, b, clk, ce, reset, qa_gt_b); input clk; // The two are only sub modules in the design and there are instanciated and connected in an upper layer module as follows module eq_node_deq_5(clk, reset, decoding_enable, p_ch, load_prob_enable, prob_id, node_id, load_shift_enable,in0, in1, in2, in3, in4, address0_0, address0_1, address0_2, address0_3, address0_4, address0_5, address1_0, address1_1, address1_2, address1_3, address1_4, address1_5, address2_0, address2_1, address2_2, address2_3, address2_4, address2_5, address3_0, address3_1, address3_2, address3_3, address3_4, address3_5, address4_0, address4_1, address4_2, address4_3, address4_4, address4_5, out0, out1, out2, out3, out4, out_ch ); //==> goes to UD counter input clk; // goes to chk node output out1; // ==> goes to chk node output out2; // ==> goes to chk node output out3; // ==> goes to chk node output out4; // ==> goes to chk node output out_ch; wire em0_sig_in; wire em1_sig_in; wire em2_sig_in; wire em3_sig_in; wire em4_sig_in; wire em0_sig_out; wire em1_sig_out; wire em2_sig_out; wire em3_sig_out; wire em4_sig_out; wire update0; wire update1; wire update2; wire update3; wire update4; wire j0; wire j1; wire j2; wire j3; wire j4; wire k0; wire k1; wire k2; wire k3; wire k4; wire in_ch; wire j_ch; wire k_ch; wire out0; wire out1; wire out2; wire out3; wire out4; wire out_ch; wire cmp_en; reg sig_ch; assign cmp_en = (prob_id == node_id & load_prob_enable)? 1'b1 : 1'b0 ; //TODO: validate the first two address lines connection with SAEED comparator7 comparator(.a(p_ch), .b({address4_0, address3_5, address3_4, address3_3, address3_2, address3_1, address3_0}), .clk(clk), .ce(cmp_en), .reset(reset), .qa_gt_b(in_ch)); em em0(.clk(clk), .reset(reset), .in_bit(em0_sig_in), .update(update0), .address({address0_5, address0_4, address0_3, address0_2, address0_1, address0_0}), .out_bit(em0_sig_out)); // some other glue logic endmodule When synthesizing the design with BuildGates, I get the following warning message. I cannot understand why I get this warning since all the address*_* signals are driven only by input of the top layer. In all other submodules these signals are all input signals and not output. The same holds for the clk and the reset signal --> WARNING: Potential multiply-driven net 'address4_5' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_5' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_4' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_3' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_2' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_1' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'address3_0' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'reset' found in module 'eq_node_deq_5' . --> WARNING: Potential multiply-driven net 'clk' found in module 'eq_node_deq_5' .
Originally posted in cdnusers.org by gkamendje
