  2. Logic Design
  3. LEC issue - "elaborate" vs. "synthesize -to_generic"
  • Subscribers 62
  • Views 2047
Yemelya
Yemelya over 14 years ago
When running  LEC on golden-(elaborate) and revise-(synthesize -to_generic) getting one NON-EQ compare point.
The following RC attributes didn't help:
set_attribute prune_unused_logic false [find [find / -inst TOP/SUB ] -ignorecase -pin *]
set_attribute prune_unused_logic false [find [find / -inst TOP ] -ignorecase -pin *]
Any ideas, what modification of RC script could be done to resolve the problem?
Thanks... Boris
  • bmiller
    bmiller over 14 years ago
     Boris,
    The normal flow is RTL-vs-mapped, and mapped-vs-final (post-incremental).  If RTL-vs-mapped fails, then I usually run RTL-vs-elab to see if it fails as well.  If you see a failure in either, I suggest you diagnose it through the GUI.  If you can't figure out what went wrong, file a Service Request or talk to your local AE for assistance.
    You shouldn't need to run elab-vs-generic for any reason
