  2. Logic Design
  3. Outputting a synthesized file in reverse order
  • Subscribers 62
  • Views 14473
Ankur S
Ankur S over 14 years ago
 I wanted to write the output of a synthesized verilog file in reverse order. Here is an example. If rtl compiler (RC) generates the following:
module .. (..) ;
// list of wires
// gate-level netlist (let's say there are only three gates)
 AND2_X1 (...);
OR2_X1 (...) ;
INV_X1 (...);
endmodule
What I would like to see is as follows:
module .. (..) ;
// list of wires
// gate-level netlist (netlist is reversed)
INV_X1 (...);
OR2_X1 (...) ;
 AND2_X1 (...);
 endmodule
Is there a command in RC that reverses the order in which netlist is written. I want to do this because it was observed that inputs of upper gates are outputs of lower gates. I need to use this netlist in C++ code and there, with the orginial ordering, I would get incorrect output. I can ofcourse do some scripting but that's cumbersome. Is there a clean way in RC?
Ankur
