  2. Logic Design
  3. RC: to Remove PG pins from a Netlist..
  • Subscribers 62
  • Views 16806
Yemelya
Yemelya over 14 years ago
There are several Power/Ground pins in the RTL design (and they cross many hierarchies). Given that they require special route in Encounter, to define them as pgpins, this pins have to be removed from the netlist.
During the synthesis, I tried to use “rm” or “set_atrribute ... pgpin”   - unsuccessfully. I believe it’s possible to remove them from the netlist by adding “pragma” to the RTL files, but since it’s an IP I don’t want to touch the RTL.
So, my question is how Pins and Nets could be removed from the Netlist during RC synthesis, if it's possible?
Thanks… Boris.
  • bmiller
    bmiller over 14 years ago
     To remove a port, you need to remove the "port_bus" object.
    rc:/> find / -port my_bidir_port
    /designs/mydesign/ports_in/my_bidir_port /designs/mydesign/ports_out/my_bidir_port
    rc:/> find / -port_bus my_bidir_port
    /designs/mydesign/port_busses_in/my_bidir_port /designs/mydesign/port_busses_out/my_bidir_port
    rc:/> rm [find / -port_bus my_bidir_port]
    rc:/>
    I hope this helps!
