  2. Logic Design
  3. Question about Encounter Conformal Equivalence Checker ...
  • Subscribers 61
  • Views 17327
Question about Encounter Conformal Equivalence Checker (EC)
archive over 20 years ago
Hello, colleagues.
I use your CAD system for formal verification.
I’ve got a question:
When I change names of interface signals in golden version of design
(but save it’s structure and behavior) and save changed file as revised,
what command shall I use in my Conformal dofile to establish equivalence?
I try to get equivalence but all my attempts resulted in follows:
Warning: Primary input ‘signal_name' in Revised has no correspondence in Golden
What have I do?
Could you help me?
Or maybe any good idea to resolve this problem or
any useful links where I can get an answer?
Thanks.
Best regards,
Valery Kartashev
Originally posted in cdnusers.org by valour
    Hi Valery,
    In order to map primary inputs, the names have to match because that is the only way the tool is able to map primary inputs. If you change the name of the primary input on one side, you need to use renaming rule to match the name on the otherside. So, as an example if you have:
    golden: IN_test
    revised: IN_test_r
    you can do
    add renaming rule rule1 "IN_test" "IN_test_r" -golden
    map key point
    This will allow Conformal to map primary input pin IN_test to revised primary input pin IN_test_r. You can also do "help add renaming rule -verbose" to get detail help on this command. I hope this answers your question.
    Yong Kim
    Originally posted in cdnusers.org by yonghk
