  2. Logic Design
  3. Latch Folding Question
  • Subscribers 61
  • Views 15385
archive over 20 years ago
I have a question about "set flatten model -lath_fold_master" command. I saw from the application note that when using this command, the remodeled circuit is slightly different from the original circuit in functionality when RESET/SET is active.
Is there a way to get this correct?
Thanks.
Originally posted in cdnusers.org by chonglee
    Could you be more specific when you say, it is different functionaly? What are the input values that cause the function of the original to be different versus the remodeled DFF? Could you also provide the rtl description of the original model?
    Yong Kim
    Originally posted in cdnusers.org by yonghk
