  2. Logic Design
  3. how to find out the FFs connected to the output of a selected...
  • Subscribers 62
  • Views 14950
how to find out the FFs connected to the output of a selected FF
gops
gops over 13 years ago
Please tell me how I can find all the clocked cells (FFs) connected to the output of a selceted FF. Also I need to find all the Fan ins from the FFs to the selected FFusing the GUI of RTL compiler.
  • bmiller
    bmiller over 13 years ago
     View solution ID 11489438 on support.cadence.com.  It shows you how to use the "fanout -struct -endpoint" command to find all the flops in the fanout of any pin.
     You can use the "gui_sv_cone <instance>" command to open any instance in a "cone" schematic GUI.  Then you can right click on any pin of that instance and open in the fanin/fanout logic cone.
      Hope this helps!
