  2. Logic Design
  3. max_fanout constraint
  • Subscribers 62
  • Views 14926
tanyacool
tanyacool over 13 years ago
 hi,
i Wanted to know as to when we set this command in the sdc file, where does this command saffects the whole design.
Whether it effects the timing, area or power of the whole design. Suppose if i set set_max_fanout =10 and next i set it to 15, what will be affected with this change?
How does a designer decides as to what should be the value for this command.
On what factors does it depends ?
How does library comes into play during this command.?
tanya
