  2. Logic Design
  3. TIP OF THE MONTH: Recommended modeling directives for RTL...
  • Subscribers 61
  • Views 14682
TIP OF THE MONTH: Recommended modeling directives for RTL-gate
archive over 19 years ago
Here's what I use as a starting point for all RTL-gate runs:
  set flatten model -gated_clock
  set flatten model -seq_constant
  set flatten model -seq_constant_x_to 0
as synthesis will often do all these transformations. It's also recommended to run:
  remodel -seq_constant -seq_constant_feedback -repeat
  map key points
after 'set system mode lec', if anything is not-mapped at that point.
I also find it useful to set these:
  set flatten model -nodff_to_dlat_feedback
  set flatten model -nodff_to_dlat_zero
as I have yet to see an implementation tool actually do these changes. Changing the default here should prevent latches from showing up in the compare report.
Originally posted in cdnusers.org by croy
