  2. Logic Design
  3. Resolving aborts after "analyze abort -compare"
  • Subscribers 61
  • Views 3418
archive over 19 years ago
I am trying to compare RTL to netlist of a design and after mapping compare and analyze abort -compare I am still left with 46 aborts. If I try to analyze the abort again the tool crashes. If I diagnose the abort I get no error candiates, 3 diagnose point clock, reset and data. The corresponding supports are 3 primary inputs and the register the reset signal is coming from which is equivalent. I am working with the RTL designers to find places where I can add partition point but so for I haven't found any satisfactory one. The logic leading to these flops are quite large but nothing to complex really and the tool has been able to resolve similar flop on these registers. I.e. test_reg[0] is equivalent but test_reg[1] is an abort point. Has anybody encountered a problem similar to this and if so how was it resolved.
Originally posted in cdnusers.org by blackj
    Hi
    'analyze abort -compare' is definitely one of the first things to do when encountering aborts.
    If you're using 6.2 and have access to an XL license (which it sounds like you do since you're using 'analyze abort') I would give 'add partition points -all' a shot next.
    analyze datapath -verbose [maybe with -share and -effort high]
    add compared points -all
    tclmode
    foreach i "low high super" {
    puts "// Info: running effort $i"
    vpx set compare effort $i
    vpx compare
    vpx usage
    vpxmode
    Note that there's always the possibility you might get false failing points when using 'add partition points'. There's a way to deal with that situation so please let me know how it turns out.
    If you still encounter aborts, consider sending Cadence the testcase. Actually, you should consider sending the testcase even if my little loop does the trick. R&D considers it a bug if 'analyze abort -compare' can't do what another command can.
    Chrystian
    Originally posted in cdnusers.org by croy
