  2. Logic Design
  3. Hello ihdl users. help required - verilog to schematic ...
  • Subscribers 61
  • Views 1957
Hello ihdl users. help required - verilog to schematic conversion
archive over 19 years ago
Hi all, I am able to import a verilog netlist into cadence from the User interface. I want to do it from the command prompt and I think the utility I will have to use is ihdl, available in the dfII/bin location of the software package. When I try it, it asks to to supply a param file and I would appreciate much, if any one can supply me with a model param file. Thanks much, Ananta
Originally posted in cdnusers.org by ananta.krishnan
    Hi Ananta
    This forum is mostly to Conformal and related formal products. Looks like ihdl is used for Custom IC Electrical Design. Can you post your question there if that's the case?
    Chrystian
    Originally posted in cdnusers.org by croy
