  2. Logic Design
  3. Warning: "work.example_pkg" not found (work.example_pkg...
  • Subscribers 61
  • Views 6043
Warning: "work.example_pkg" not found (work.example_pkg found and used)
archive over 19 years ago
I'm new to Conformal. I'm getting a warning message as follows:
Warning: example.vhd:37:26: "work.example_pkg" not found (work.example_pkg found and used).
Any idea what it's talking about? Any help would be highly appreciated.
Meshbah
Originally posted in cdnusers.org by Meshbah
    Hi Meshbah
    Apologies for the delay. I just tried to reproduce the warning message. It's related to reading in VHDL libraries.
    Looks like you're doing:
    read design -vhdl \
    example_pkg.vhd \
    example.vhd
    The recommended way is actually:
    read design -vhdl \
    example.vhd \
    -mapfile work example_pkg.vhd
    That way the package is explicitly put into library 'work' and the warning won't be triggered. It will still work either way in this case though.
    Chrystian
    P.S. I usually like to put all the RTL files, followed by -map arguments, and end with -mapfile ones. It's best not to mix them up all over the place.
    Originally posted in cdnusers.org by croy
