  2. Logic Design
  3. How to handle DesignWare modules
  • Subscribers 61
  • Views 16206
archive over 19 years ago
Hi all,
      I'm stuck with the  divider module in my design It compares till 61% and hongs there.One with 32 bith showed equivalent but this one is bigger .Run time for 32 bit was 1.5 days.The other one
even after two days shows 61% and aborts with two points.
How to handle such DW modules in the design.
I used "set implementation divider -cla2 -both" and using 6.1 version.
Kindly help me in this  regard.
Originally posted in cdnusers.org by ranga
    Hi Ranga
    I don't have much experience with this particular case. I would recommend you file an SR through http://sourcelink.cadence.com so an engineer from CS can investigate.
    Please include the DC (or RC) version you're using and if you have access to Conformal-XL (Ultra) licenses.
    Chrystian
    Originally posted in cdnusers.org by croy
