  2. Logic Design
  3. How to tell conformal that some input combinations do not...
  • Subscribers 61
  • Views 18967
How to tell conformal that some input combinations do not occur
archive over 19 years ago
Hi
I have a 3bit input signal which is coded such that it does not take the values of 110 and 111. How will I be able to put such a constraint on the input pins in conformal?
Prasad.
Originally posted in cdnusers.org by anssprasad
    hi prasad,
    this can be done. i suggest you contact support. they
    will send you an appnote describing how this can be
    done.
    -- mm
    Originally posted in cdnusers.org by makkarm
    Hi Masood,
    I tried contacting the support guys, but for some reason they were not ready to resolve the issue. I would try again with them, but if you are having any app notes or any other source which would help me please mail to nss.prasadaddagarla@gdatech.co.in
    Prasad.
    Hi Prasad
    Preventing the first 2 bits from being 11 is good enough in your particular case. For that, use 'add pin constraint zero_one_hot bit2 bit1'. No need to constraint bit0.
    Chrystian
    Originally posted in cdnusers.org by croy
    Hi Chrystian,
    You are right. I have already employed that with this particular case. But I am curious to know what can be done if such a solution is not available. I am pretty sure that somewhere and somewhen I would need it!
    Prasad.
    Hi Prasad
    On Sourcelink, search for "constraint" under Conformal (do not include Conformal Constraint Designer). Results 1, 2, and 4 are what you are looking for.
    Chrystian
    Hi Chrystian,
    It was of great help. Thanks.
    Prasad.
