  2. Logic Design
  3. TIP OF THE MONTH: Beware Incomplete Libraries
  • Subscribers 61
  • Views 14353
archive over 19 years ago
I recently encountered a testcase that confirmed the old saying: "garbage in, garbage out".
The customer was running a gate-gate verification using an incorrect Liberty library (source for .db) and that caused a difference to be missed. Here are the details:
  golden:                  revised:
    A --|A     |             C --|A     |
    B --|B    Z|-- Z         B --|B    Z|-- Z
    C --|C     |             A --|C     |
Note the swapped connections for pins A and C. The problem was that the cell was incorrectly described as:
       |A          |
       |B---buf---Z|
       |C          |
i.e. A and C had no effect on output Z. Hence the 2 designs are equivalent, based on that incorrect, incomplete library.
Some lessons:
  1. use Verilog libraries. Running synthesis and verification of the synthesis using the same Liberty or .db library can cause inconsistencies to be missed
  2. only use Liberty if you validated it against the Verilog*
  3. leaving a cell black-boxed is better than reading in an incorrect model**
  4. consider using Conformal GXL to validate the Verilog libraries against the Spice
Again, remember: "garbage in, garbage out"
*  on Sourcelink, search for "library qualification" under Conformal for details on how to run it. It should be the first solution search returns
** we do have an AE-ware script to do strict equivalence checking, where any changes to the connections and/or cell names get flagged
Originally posted in cdnusers.org by croy
