  2. Logic Design
  3. 2nd TIP OF THE MONTH : Beware Incomplete Libraries
  • Subscribers 62
  • Views 15037
archive over 19 years ago
I recently encountered a testcase that confirmed the old saying: "garbage in, garbage out".
The customer was running a gate-gate verification using an incorrect Liberty library (source for .db) and that caused a difference to be missed. Here are the details:
  golden:                  revised:
    A --|A      |             C --|A     |
    B --|B    Z|-- Z        B --|B    Z|-- Z
    C --|C     |              A --|C     |
Note the swapped connections for pins A and C. The problem was that the cell was incorrectly described as:
       |A          |
       |B---buf---Z|
       |C          |
i.e. A and C had no effect on output Z. Hence the 2 designs are equivalent, based on that incorrect library.
Lesson 1: use Verilog libraries. Running synthesis and verification of the synthesis using the same Liberty or .db library can cause inconsistencies to be missed
Lesson 2: only use Liberty if you validated it against the Verilog*
Lesson 3: leaving a cell black-boxed is better than reading in an incorrect model**
Lesson 4: consider using Conformal GXL to validate the Verilog libraries against the Spice
Again, remember: "garbage in, garbage out"
*  on Sourcelink, search for "library qualification" under Conformal for details on how to run it
** we do have an AE-ware script to do strict equivalence checking, where any changes to the connections and/or cell names get flagged.
Originally posted in cdnusers.org by croy
    Bump. Just saw this at another customer. A couple of errant 'assign' statements in the Verilog model was causing an analog cell NOT to be black-boxed. See Lesson 3 above.
    Chrystian
  • croy
    croy over 16 years ago
    Bump. Just saw this at another customer again.
    Chrystian
