  2. Logic Design
  3. How to tell conformal to ignore a module
  • Subscribers 61
  • Views 17584
archive over 19 years ago
Hi
How to tell conformal to ignore a particular module. I have a repeater which I want the tool to ignore. I tried using the "add notranslate module" command but then it backboxes the module and shows it as a non-equivalent mapping point. I dont want it to compare for black box equivalence. How is this possible?
Prasad.
Originally posted in cdnusers.org by anssprasad
    Hi Prasad
    Not sure what you mean by repeater but if you want to sweep something under the rug so to speak, the easiest and potentially most dangerous way is to use the 'delete compared point' command.
    set system mode lec
    add compare points -all
    delete compare point
    compare
    Again, this is the easiest and *most dangerous* way to remove something from comparison.
    Chrystian
    Originally posted in cdnusers.org by croy
